cylinder head/block dowel pin
On my 92 Accord I removed the cylinder head and cannot seem to pull out one of the two dowel pins) that insert into the block so that the head gasket can be positioned on it correctly when doing that task. The little part I'm talking about is the cylindrical part #23 as shown on this diagram/listing: http://estore.honda.com/honda/parts/...n=&b=E++10&dl=
Gripping and twisting with pliers it's still not coming out. The other one pulled right out easily. I think I already buggered it up little by having to pull and twist on it excessively and might have to get a new one. But meanwhile it's stuck in there (in the cylinder head insert recess). Any suggestions on how I might get it out without possibly it tearing and breaking off on the inside or something. I was thinking maybe try heating it up some with a torch? Or not a good idea?
Some break cleaner and two picks at the top part in the head and a few good tugs......rotate picks 90 and another go????
If you heat, heat the head so it expands away from the dowel......use the pick again to try to pull it from the top of the dowel.
Can't remember, is there a "slot" in the dowel......or is is solid?
Some break cleaner and two picks at the top part in the head and a few good tugs......rotate picks 90 and another go???? If you heat, heat the head so it expands away from the dowel......use the pick again to try to pull it from the top of the dowel. Can't remember, is there a "slot" in the dowel......or is is solid?
Sorry.....meant did it have a slot or a solid outside.
If you are going for a new one anyway....a block of wood for leverage and rip that bad boy out. One side of the wood to the head, then on the other that is where you can pry the vice grips on the wood......kind of like removing a nail with a hammer, a piece of wood in between helps get that sucker out.......you protect the surface of the head from damage.
Right, yeah important not to take a chance on damaging the head, at least protect it like you said with some wood if I'm gonna be prying against it with vicegrips. Thanks. I'll post back with success story or lack thereof.
If you are goinf for a new one anyway....a block of wood for leverage and rip that bad boy out. One side of the wood to the head, then on the other that is where you can pry the vice grips on the wood......kind of like removing a nail with a hammer, a piece of wood in between helps get that sucker out.......you protect the surface of the head from damage.
I did as suggested (quoted above) and ripped (actually leveraged and ripped) that bad boy out. I used a small size vice grips and a wooden paint stirrer stick to protect the head while I pried against it. It took a couple of tries, it didn't want to come easily, and it ripped a little so good thing I already ordered a new one. But hey that sucker is out. Thanks
82009_honda
Nov 26, 2009 09:17 AM
