"D4" gear light flashing ?!
Old Sep 2, 2011 | 05:32 PM
chrisjames105's Avatar
Default "D4" gear light flashing ?!
95 Accord v6, the light around the drive gear up on the dash starting flashing, steady flash, and Im wondering if thats some kind of transmission problem? Any info is appreciated.
Old Sep 2, 2011 | 05:40 PM
MessAround's Avatar
Almost A Senior Member
Might be a trans. code but I'm not sure that applies if it's constant on while you're not jumping the service connectors.
Old Sep 2, 2011 | 07:42 PM
A steady flash (going on/off presumably) indicates an error code is stored. Short service check connector and D4 will blink the code/s. Check DIY forum for guidance on extracting codes, same procedure as engine codes.
Old Sep 3, 2011 | 11:20 PM
Honda_Lady's Avatar
if it's flashing you definitely need to check the code. if it's just on and your not in that gear it could be the computer. i had a problem like that with it just on and not in that gear with shifting problems and replace the TCU with a used one and it fixed that particular problem. definitely more info needed to tell you any more.
PELLEY
Oct 1, 2013 06:07 AM
ysbarney
Oct 1, 2012 06:04 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
HondaAficionado
Nov 30, 2010 05:24 PM
skysa
Nov 9, 2009 06:24 AM
