D4 light on, no start
Old Jul 16, 2024 | 07:46 PM
  #91
TrojanFan's Avatar
Oh, and how do I add my vehicle info?
Old Jul 16, 2024 | 09:08 PM
  #92
Click on your profile at the top of the page and then edit signature.
Try swapping injectors 3 and 4 with 1 and 2 and see if the code moves.
Does your car have coils for each plug or a distributor? If coils for each plug, you can try swapping 3 and 4 with 1 and 2 first, then try the injectors. If you have a distributor, you might want to pull off the cap and see if you have any corrosion on the contacts for 3 and 4.
Old Jul 16, 2024 | 09:54 PM
  #93
TrojanFan's Avatar
I has a distributor. I swapped the distributor with one I know that works. But it still idled the same
Old Jul 20, 2024 | 02:47 PM
  #94
TrojanFan's Avatar
I unplugged the idle air control valve and noticed the idle stayed the same. The only difference was when I gave it gas the rpms were quicker to go down. Other then that the rpms stayed the same whether it was plugged in or not. Any thoughts?
Old Jul 20, 2024 | 03:27 PM
  #95
Are you still trying to figure out the P0303 and P0304 codes? I'm not sure unplugging the IAC would resolve the issue, because the IAC could affect all four cylinders.
Did you try moving the fuel injectors to see if the codes change?
Old Jul 20, 2024 | 06:46 PM
  #96
TrojanFan's Avatar
I'm going to do that next. It's almost a hundred today. So I'm gonna have to wait until it cools down abit
Old Jul 28, 2024 | 11:04 PM
  #97
TrojanFan's Avatar
I swapped in some used injectors in the three and four cylinders. I cleaned the egr passage and the egr valve. When I started it it reved up and down with no codes. So I bought a new IA valve and put that in. Now it's showing no codes but it's still idling up and down. Any help would really be appreciated
Old Jul 28, 2024 | 11:26 PM
  #98
TrojanFan's Avatar
This is what it's doing
Old Jul 29, 2024 | 08:17 PM
  #99
Does the engine sound normal? The hear a high pitched noise in the video that matches the rpm.
When the engine is cold, I'd remove the radiator cap and allow any air in the system to purge. Air in the cooling system can mess with the idle.
Old Jul 30, 2024 | 12:22 AM
  #100
TrojanFan's Avatar
Yeah there is a high pitch noise when it's doing that. I don't know what's going on with it
