Dash Brake Light
Old Jun 16, 2008 | 06:33 PM
edchristian
Default Dash Brake Light
Sorry if this is repeat - I cannot get "search" to work on this forum. 2000 Accord LX 4CYL. I have brake light on dash coming on in morning and then goes out after awhile. Do not think it is parking brake. What should I do first? Brakes do not feel mushy, they work fine. Should I try putting new fluid in and bleeding brakes?
Also link to Bleeding Brakes in DIY section is bad.
Ed
Old Jun 16, 2008 | 07:02 PM
ford's Avatar
Default RE: Dash Brake Light
hmm..all i know is that the brake light in the dash just corresponds to your hand brake...maybe you need to check your hand brake wirings and maybe adjust your hand brake...
Old Jun 16, 2008 | 08:19 PM
Pull the brake fluid reservoir inlet screen and notch opposite sides of lower "flap seal" end w/ scissors. This breaks the hydraulic lock which is holding the fluid level sensor down. It worked for me on my 97 2.5TL which had this problem for over a year. Has not returned since. Some searching on this site may find the answer, but I don't remember if answer came from here.
Old Jun 16, 2008 | 11:47 PM
Or if its the BRAKE LAMP warning light, then check the bulbs in taillight clusters.
The other BRAKE warning is either the handbrake switch or the fluid reservoir float switch.
victorywhity
Mar 24, 2011 09:37 PM
gypsyman
Sep 25, 2007 12:26 PM
ivrex
Dec 10, 2006 03:24 PM
lea02coupe
Oct 1, 2006 12:31 AM
