desparate for help w/1994 accord starting/stalling problem
Old Jun 24, 2011 | 04:50 PM
Is CEL still on? If so what codes?
If you still have Code 9, I suggest removing connector B at ECU and measuring the CYP sensor resistance at connector B pins. Connector B Pins are 11 (Org) & 12 (Wht), and CYP resistance should be 700-1300 ohms for B1 engine or 350-700 ohms for B2 engine. If sensor resistance checks good and Code 9 is present, then ECU is very likely bad. That's what I did before replacing my ECU, which fixed the problem.
You need shop manual and reference connector B in Fuel & Emissions section.
Old Jul 1, 2011 | 01:48 PM
JimboBigLotto's Avatar
Default it's FIXED!!!!!!!!!!!!!
THANK YOU ALL!!! Turns out it was the ECM after all. I could never have done it without your assistance! 2 years of troubles FIXED in an a few short hours! I'll be back! thanks.
Old Jul 2, 2011 | 11:51 AM
Glad you got it and thanks for the update.
Old Jul 2, 2011 | 01:46 PM
Thanks for posting your fix.
I used to think Honda ECU's were bullet proof since I've never seen a well documented post of ECU being the fix. However in last 1-2 yrs, this has happened several times, including to myself.
I suspect the problem occurs where the connector leads are bridged from connector to circuit board. Either of these solder connections offers possibility of fatigue failure due to thermal load cycling. Solder is notoriously poor in fatigue. I repaired my 94 EX circuit board but did not reinstall due to inexpensive replacement cost w/ used.
Regards
Ryan Boswell
Oct 30, 2013 06:46 AM
george3405
Feb 25, 2011 08:28 PM
8lug
Feb 21, 2011 10:32 AM
Garrett
Apr 3, 2009 03:52 PM
Derrick Stevens
Jun 13, 2007 02:52 PM
