dim headlights
Old Aug 24, 2010 | 07:02 PM
turbo accord wagon's Avatar
Default dim headlights
i have a 5th gen wag. one of my headlights was out and so i replaced the bulb but it is still dim. its like its not getting enough power to light it all the way or like its fading out. any ideas?
Old Aug 26, 2010 | 07:25 PM
anything?
Old Aug 26, 2010 | 07:31 PM
Unplug the dim bulb and check that the pins are not corroded. Grab a volt meter. See if you have 12V from pin of the non-black wire to body ground (like a valve cover bolt) when you have the headlight turned on.
If you have 12V, I would clean the ground bracket. Get the 94 shop manual from the spooner link I posted in the Online Manuals thread in the DIY section. The electrical section will show where the ground is located.
jfralph
Oct 2, 2013 09:07 AM
rpreziosi
Jan 18, 2010 07:11 AM
NoMoreVWs
Nov 25, 2007 09:04 PM
accorddriverc
Jun 29, 2006 05:24 PM
72mustang
Feb 12, 2006 10:16 PM
