dim headlights
Unplug the dim bulb and check that the pins are not corroded. Grab a volt meter. See if you have 12V from pin of the non-black wire to body ground (like a valve cover bolt) when you have the headlight turned on.
If you have 12V, I would clean the ground bracket. Get the 94 shop manual from the spooner link I posted in the Online Manuals thread in the DIY section. The electrical section will show where the ground is located.
