dipstick tube removal for timing belt
Old Jul 3, 2014 | 02:25 AM
linsalata's Avatar
Default dipstick tube removal for timing belt
So I recently (yesterday) replaced my timing belt/water pump/pulleys... there was a moment of confusion when i got to the part about removing the oil dipstick tube...I didn't remove the tube just the dipstick...I guess I misread the manual... anyway everything is running great but I'm curious if I could have damaged something by not removing the tube itself instead of just the dipstick? Any insight would be greatly appreciated! 2004 ACCORD EX 3.0 V6 VTEC
Old Jul 3, 2014 | 07:50 AM
I looked through steps in Honda Shop Manual for 2004 V6 and did not find a step for removing oil dipstick and/or dipstick tube. What source of information asked for this step?
Old Jul 3, 2014 | 03:03 PM
linsalata's Avatar
The haynes manual said to do it but I didn't understand why..it was an oddesy/accord haynes manual so maybe that step was meant for the oddesys... everything is running good though
Old Jul 3, 2014 | 03:12 PM
EXV6NIGHTHAWK's Avatar
I did my own timing belt too, and didn't see anything about removing the dipstick tube. I did see a timing belt video on an older Acura TL, and the dipstick tube had to be removed on that model. I guess the Haynes manual covers a lot of different models, so they include steps for all of them. I used the Honda factory manual.
Did you have any trouble getting the crank pulley bolt off? It seems to be the biggest problem for most shade-tree guys like us.
Old Jul 3, 2014 | 04:44 PM
I have a 03 MDX w/ 3.5L V6 and did timing belt 3 yrs ago. No dipstick removal was req'd.
Yes, it is a challenge to remove V6 or 4-cyl crankshaft pulley bolt. For the MDX, I used 500+ ft-lb ingersol rand 1/2" air impact and 5 mins or so of propane heat on bolt head. Spun off easily. This was after trying manual method (breaker bar on restraint tool and 2nd breaker bar w/ cheater pipe) and straight air impacting.
Old Jul 4, 2014 | 12:17 AM
linsalata's Avatar
Yes I had one helluva time getting that stinkin bolt off. I ended up renting the removal tool from honda for 30 dollars because a strap wrench wasnt working. That plus a 5 foot breaker bar and some elbow grease. I also put the engine mount back in for the bolt removal because there was a whole lot of engine flex when trying to remove it. I had an impact gun but it wasn't doing the trick so I just ended up doing it the old fashioned way. Im just glad it all worked out because the quote from honda was 1300 for everything I did and I was able to pickup the kit, coolant, and rent that tool all for 230.
kttn
Jan 6, 2015 10:45 AM
dpotter
Dec 16, 2013 12:51 AM
vman858
Jun 23, 2008 12:14 PM
Tony1M
Apr 1, 2007 05:42 PM
joshuaaaronalpert
May 29, 2005 11:42 PM
