Directions for replacing front axle on 1993 Accord
No way we can swing the money needed to have our mechanic change the drivers side front axle and tighten the ball joints. Are there any DETAILED directions anywhere so hubby can look to see if he can do this himself? I've been looking and am coming up blank. A video would be most awesome.
THanks!!
Oh.. this is a 1993 Honda Accord 5 speed.
THanks!!
Go on youtube and search "changing honda accord axle". The first 5 or 6 results all look good.
Basically you undo the axle nut, break the lower ball joint, use a large screw driver or pry bar to pry the axle out of the differential(depending on if its driver side or passenger side you may need to remove the 3 bolts on the half shaft), replace seal on transmission. Do steps in reverse order, then refill the transmission fluid.
That is the brief explanation on how.
The only thing that may be difficult is without an impact gun it can be difficult to tighten the bolt on the ball joint.
sunny393
Dec 17, 2007 01:46 PM
