Directions for replacing front axle on 1993 Accord
Old Apr 18, 2012 | 01:51 PM
gfam's Avatar
Default Directions for replacing front axle on 1993 Accord
No way we can swing the money needed to have our mechanic change the drivers side front axle and tighten the ball joints. Are there any DETAILED directions anywhere so hubby can look to see if he can do this himself? I've been looking and am coming up blank. A video would be most awesome.
THanks!!
Oh.. this is a 1993 Honda Accord 5 speed.
Old Apr 18, 2012 | 02:04 PM
Go on youtube and search "changing honda accord axle". The first 5 or 6 results all look good.
Basically you undo the axle nut, break the lower ball joint, use a large screw driver or pry bar to pry the axle out of the differential(depending on if its driver side or passenger side you may need to remove the 3 bolts on the half shaft), replace seal on transmission. Do steps in reverse order, then refill the transmission fluid.
That is the brief explanation on how.
The only thing that may be difficult is without an impact gun it can be difficult to tighten the bolt on the ball joint.
Old Apr 18, 2012 | 02:24 PM
gfam's Avatar
Thanks. Just watched a few. Looks like it's beyond our realm of ability. We don't have an impact wrench for one. Phewie.
Old Apr 18, 2012 | 04:38 PM
I wouldn't expect a mechanic to charge very much to replace it. They should easily be able to replace it in less than an hour.
Old Apr 19, 2012 | 07:13 AM
gfam's Avatar
Really? My quote was over $800 for left axle, tighten ball joint on left side and alignment. Is that too much??
Old Apr 19, 2012 | 08:10 AM
crispin's Avatar
yes it is $400 should more than cover it.
Old Apr 19, 2012 | 08:48 AM
The axle itself is only $50-80. Then an hour or so to install plus transmission fluid. I would expect this job to be $150-200 plus maybe $100-150 to have an alignment done. I would find a new mechanic.
pow3rid
Oct 19, 2012 10:13 PM
R.Weed93
Apr 20, 2012 03:03 PM
l Ottesen07 l
Oct 6, 2009 03:20 AM
sunny393
Dec 17, 2007 01:46 PM
nixalot
Jan 25, 2007 02:02 PM
