Disconnect cruise control module?
Old Jun 5, 2013 | 06:25 PM
motor's Avatar
Default Disconnect cruise control module?
Hey All,
My CC module is hanging down under the dash and the bolts holding it down are missing. Can't see where they mount, and after searching bent upside down in the footwell, impossible to reach if I did. Got it ziptied to the steering column now, but wondered if I could just disconnect it without affecting my fuel injected motor's operation.
Thanks,
Old Jun 5, 2013 | 06:31 PM
kayweb's Avatar
cruise control module? You mean the buttons on the column?
Yes, you can disconnect it. It's pretty straightforward. Provided your car has a throttle cable, there will be a second cable that attaches to the cruise control actuator, probably mounted on the firewall in your engine bay. disconnect that cable, unplug the buttons from your wiring harness, and drive on.
Old Jun 5, 2013 | 08:33 PM
The year and some basic information about your car would help.
Old Jun 6, 2013 | 11:28 AM
motor's Avatar
1991 Accord EX, auto, fuel injected. Pics to follow - thanks!
Old Jun 6, 2013 | 12:01 PM
motor's Avatar
The box has two mounting tabs and a multi-prong connector at one end. The CC switch is on the dash next to the sunroof control, not on the column.
The car runs fine, I just don't want to screw it up! I await your replies.
Old Jul 1, 2013 | 06:57 AM
kayweb's Avatar
Wow, I forgot to reply to this.
The button to enable cruise control should slot into a hole in the dashboard and stay in place there. Any pictures to help out with this?
Old Jul 1, 2013 | 11:58 AM
Cruise control module on these models is mounted at lower side of under-dash, just barely out of sight. I had to remove one for access to the Main Fuel Relay. I think its mounted on brackets just to left of steering wheel. Probably 10mm bolts, but could be stud mounted w/ retaining nuts.
Old Jul 1, 2013 | 12:15 PM
The attached pic. is where it is mounted, like TexasHonda described.
Old Jul 2, 2013 | 06:32 PM
motor's Avatar
Thanks for the pic!
Da Flash
Apr 28, 2011 08:07 PM
rudescotsman
Jan 18, 2010 07:52 AM
uraceulose
Oct 6, 2009 08:19 PM
dboy
Jul 10, 2007 11:04 AM
ducatiff
Jul 7, 2007 12:22 AM
