Sponsored by:
Sponsored by:
Do I need a new starter?
Old 02-29-2016, 03:24 PM
drdba's Avatar
Default Do I need a new starter?
I have a 2003 Accord Coupe, 107K miles, new battery, and new alternator.
I am getting the "electronic buzzing" sound more often when I start my car. I realize that you need to turn the key fast, but this awful buzzing sound is getting more frequent during start ups?
Do I need to replace my starter?
Old 03-02-2016, 03:23 PM
holmesnmanny's Avatar
If you have an aftermarket alarm it's possible the starter disable function is going bad.
Old 03-02-2016, 03:42 PM
Some early 7th gen Accords had issues with the ignition switch or starter cut relay which will result in the buzzing noise. You can try swapping one of the same type relays in the driver's under-dash fuse relay box to see if it makes a difference.
Old 03-04-2016, 12:26 AM
UhOh's Avatar
If you can start the car each time you turn the key the starter is working.
But what's with this needing to turn the key to start position fast?
Never heard that before. Is time delay related to the buzzing for your car?
Old 04-03-2016, 05:22 AM
Please update this when you find the problem. Thanks
tony_toca
02-04-2011 10:10 AM
darkgreen18290
09-28-2010 12:47 AM
thomask
05-26-2010 05:35 PM
dickup
04-18-2008 08:20 AM
FIEROgtFREAK
05-15-2006 11:49 PM
Quick Reply: Do I need a new starter?
