donor 96-97 F22b1 engine swap into 95 ex accord
Oil leaking where the distributor mounts against the cylinder head is easy. There's an O-ring on the part of the distributor that goes into the head.
A bad seal INSIDE the distributor would leak out where the distributor cap meets the body of the distributor. Officially that seal isn't replaceable, but some people have found a seal that works, for certain years/versions of Accord. Search for those threads on this board.
I replaced both seals, the inner-seal I believe is the problem and it still leaks. I bought the set from napa. I don't see oil residue where the distributor meets the engine block, so it's likely still the internal seal is not right. I used a socket to seat it with a hammer. This sucks. It leaks quite a bit and leaks through the starter area all the way down towards the edge of the transmission onto the floor. Good news is that it's not a rear main seal problem from what I can tell and this is it. Valve cover gasket could still be a problem, but If I put my hand where the plastic meets the distributor housing I get oil there at the bottom on my hand. A non-oem distributor won't hold up well and I'd like to find a way to fix this, but it's not looking great at this point. A non-OEM replacement is about $80 on amazon, another seal kit is $13. I have always heard never go non-OEM on honda distirbutors in terms of reliability. The 96-97 distributor that came with it is completely different, otherwise i'd swap the guts from this model year over to it and call it a day. Any recommendations at this point?
h23a-95 accord
Aug 2, 2022 01:15 PM
