Door open and brake light flickering '99 Accord LX
Old Jan 12, 2018 | 03:55 PM
The Toecutter's Avatar
Originally Posted by bmwgsrider
I went to Oreilly's to get a fault code and there was no fault code. They put a tester on the battery and it came back to Alternator volt reg failed
This time I will get an alternator from Honda... I am wondering if people have problems with the Electrical Load Detector or Power Control Module? And if this would or could cause the symptoms I am having. What symptoms would ELD or PCM do to the vehicle?
Thanks so much in advance.
If the voltage regulator failed, that should have turned on a CEL light. If there's an issue with the ELD or the PCM, they will turn on the CEL light.
It might have been your replacement alternator had an issue all along, and finally gave up the ghost.
Old Jan 12, 2018 | 05:13 PM
bmwgsrider's Avatar
Thanks. I hope I have no more issues with OEM alternator... will drive it like I stole it after I get it installed today.
Old Jan 23, 2022 | 12:28 PM
Thomro's Avatar
Default Same here.
Any solution? My problem is exactly the same.
Old Jan 24, 2022 | 06:35 PM
bmwgsrider posted this about four years ago, so you may not get a reply. Have you tried the troubleshooting steps suggested in the messages?
Old Oct 13, 2022 | 06:11 PM
tripleplay's Avatar
Having same issue for months now and still haven’t been able to pinpoint after following all the troubleshooting in thread.
Car is running fine otherwise so no clue on what the problem could be.
Any updates from your issue?
Hondahonda
Aug 22, 2012 08:14 PM
edtheace
Nov 23, 2011 08:24 AM
nismoawan
Oct 23, 2011 10:25 PM
Brian
Feb 2, 2006 08:04 PM
