Sponsored by:
Sponsored by:
Door Panel Plastic Membrane
Old 03-08-2012, 08:53 PM
rah140's Avatar
Default Door Panel Plastic Membrane
I have a 2012 Honda Accord EXL-V6. Underneath the door panel there is a plastic membrane between the door frame and the door panel. The plastic membrane is held to the door frame with some typy of adhesive wich feels like a tacky, plyable caulk. I have to replace the plastic membrane and don't know what to use to hold the plastic film to the door.
Does this adhesive come with the plastic film that I am buying from the dealer? What kind of adhesive should I use to hold the plastic to the door frame?
Thank you for your help.
Old 03-08-2012, 09:38 PM
I can't remember the name for the product I found. I bought it at car quest. It was sold in a roll and used to seal a car window.
Old 03-09-2012, 12:08 AM
You might even be able to heat it up with a hairdryer, peel the plastic, & re-use the sticky goo.
If you use something like caulking, that works fine until the next time you have to remove the film. It basically protects the inner door panel from rainwater.
Old 03-09-2012, 12:47 AM
They also have that product over at your local AutoZone store...
Kelsen
DIY Answers.
04-07-2020 11:46 PM
Davenje
10-19-2013 06:30 PM
d0n
01-08-2013 08:18 PM
ThatOneGuy352
02-19-2011 10:32 AM
Quick Reply: Door Panel Plastic Membrane
