The dreaded "It's making a weird noise" question
Old Dec 31, 2014 | 09:44 PM
jpilk99's Avatar
Default The dreaded "It's making a weird noise" question
I know; I hate when people throw that question on the table while looking for mechanical help.
My '08 Accord LX 2.4 four cylinder automatic with 112k miles has been running like a champ for the 2 years I've owned it. Over the last few weeks, especially - if not exclusively - when I first start it up and drive up the road, I'm hearing a sound ...almost like the exhaust shield is loose. It lasts only a second or two and then stops. I feel like it loses power during this sound too, but, I also feel like, as soon as I hear it, that I panic and let up on the gas.
Timing chain? Clutch slip? Exhaust shield?
I've read a lot about timing chains, and belts, and believe my car has a chain. Unless the tensioner is failing, it sounds like I don't have to really worry about the chain.
Clutch? This sound doesn't seem like a clutch issue. I know exhaust shield noises and am 98% sure this ain't the issue.
Also, after a few minutes of driving, the condition seems to go away. I would say I hear it maybe 3, 4, or 5 times during the first few minutes of driving, and then it stops.
Also, I noticed my oil light, (picture of the oil can), flicker -- and I'm going to check it in the morning. Who knows, maybe that's the issue? I wouldn't think being low on oil would ...present itself this way.
Any thoughts? Thanks so much.
Jay
Old Dec 31, 2014 | 10:11 PM
Low oil can affect the VTC actuator, which will make a grinding noise. Check and add oil if necessary.
If oil level is not low, issue may be related to faulty VTC actuator. See my post #3 in this thread:
https://www.hondaaccordforum.com/for...banging-60188/
Old Jan 2, 2015 | 10:29 AM
jpilk99's Avatar
Thanks rebull!
I believe it was the low oil - I'm sucha tool!!!! Just changed it today and made sure there's plenty in. thanks again!
Old Jan 2, 2015 | 11:26 AM
Good to hear the issue may be resolved. You're welcome.
May 27, 2019 01:20 PM
cuda6pak
Oct 5, 2013 09:38 AM
joenintiesc
Apr 14, 2013 07:29 AM
jalospride
Nov 25, 2010 07:58 AM
corvetteking
Jun 26, 2010 12:26 AM
