EGR valve and distributor???
Old Jan 13, 2010 | 12:45 PM
cuz's Avatar
cuz
Default EGR valve and distributor???
I have a 98 4 cylinder Accord vtec with 274,000 miles. After driving 220 miles with no problem I stopped for about 10 minutes. When I started the car back up to drive 1 mile to a friends house it ran rough and did so on the drive back. The next morning I started it a few times to see if I could figure out what was wrong. It ran rough then died and wouldn't start again. I took it to a shop and the codes indicated the EGR valve was bad and the computer wasn't receiving any signal from the distributor. The tech said I also needed a new distributor. It just seemed unlikely to me that the EGR valve and the distributor would suddenly go at the same time. Any ideas or opinions or ideas would be greatly appreciated.
Old Jan 13, 2010 | 02:30 PM
If he told you the code numbers (P1234) we'd be a little better off. But it sounds like too much of a coincidence.
Check the wiring plug at the distributor for loose/dirty/corroded or stuff like that.
Earlier 4-cyl cars had EGR passages that get plugged up with carbon, but I thought(?) by 1998 that was less likely. Still, look for stuff in the DIY section about EGR cleaning.
This belongs in General Tech, so I'll move it. If it turns into a detailed procedure write-up I can move it back.
Old Jan 13, 2010 | 03:31 PM
deserthonda's Avatar
like Jim says you need to post the code .. starts with P followed by 4 numbers ..
is this a shop that specializes on Hondas ??
Old Jan 14, 2010 | 12:04 AM
cuz's Avatar
cuz
The shop does specialize in Honda repair. I'm on a business trip at the time and spoke to the tech over the phone. I'll try to call them and get the codes in the morning. In the mean time...thanks.
NZXTInerTia
Jul 20, 2012 03:06 AM
archangel_1988
Dec 13, 2011 11:43 PM
RJLhonda
Sep 9, 2008 01:05 AM
pow3rid
Feb 4, 2007 04:02 AM
Buckeye
May 8, 2005 12:41 AM
