electrical problems- door locks/windows/seatbelt
Old Jan 8, 2008 | 06:01 PM
mark28269
Default electrical problems- door locks/windows/seatbelt
Does the car computer also control the door locks, seat beltsand the window electronics.
Door locks- when I lock the driver door it unlocks the other three doors. So I thought it was obvious to take the switch out and switch the wires around so that now this door works like the others. NO,it now does the same but now when I lock the driver door it would unlock the other three doors. What is going on?
The windows- rear left, I thought the motor was burned out.While replacing the driver door motor I noticed that if I push up on the switch to the back left (in driver door panel) and then push down on the back left window switch it will go down. To get it back up, I push down on the rear switch on the driver door panel. It goes up automatically. strange.What is going on?
Driver self strapping seatbelt- When I open the door it locks you in.When I close the door it opens (moves to the front). I cannot use the seatbelt. How do I fix this?
Old Jan 8, 2008 | 09:07 PM
nafango2's Avatar
Default RE: electrical problems- door locks/windows/seatbelt
as far as the locks go, are you trying to say that when you reversed the switch it worked exactly the same?
are you pressing the switch or just locking the door?
you need to be more descriptive.
Windows, good luck. sounds like either a wiring problem or a switch problem, if the problem is exactly how you described. you might have to do some major wire tracing, which trust me, is not fun. Nor easy. Your better off taking it to a dealership.
As far as the seatbelts go, i believe honda has a 250k mile warranty on the seatbelts, take them in and they should fix them.
Put your year/model/transmission type/trim in your profile, as well as tell us what it is.
Antiriad
Jul 23, 2014 07:51 AM
paulson524
Aug 10, 2013 10:13 AM
losrico
Oct 18, 2012 05:26 PM
islandhonda
Sep 13, 2011 12:02 PM
dothedrewtoo
Oct 20, 2008 11:47 PM
