Electrical question
Old Oct 21, 2008 | 08:02 AM
bigdawg74's Avatar
Default Electrical question
I'm trying to get the fog/driving lights on my 1990 Accord LX to work. Popped the dash switch out and took it to Autozone for testing; it was good. There is no power to the switch. I couldn't find a fuse that was bad. What would kill power to the switch?
Old Oct 21, 2008 | 10:20 AM
finch13's Avatar
Default RE: Electrical question
Are you sure the ground isn't bad? When you tested for power, where did the put the negative lead of the voltmeter? Black wire or grounded to chassis?
Old Oct 21, 2008 | 06:46 PM
bigdawg74's Avatar
I just used a two prong, red/black pocket sized circuit tester, not a voltmeter (first mistake?). I poked the two leads every which way to every combination of the plug holes, and no light, so I assumed there was no power to the switch (second mistake?). Electrical work is not my forte, obviously....
Old Oct 21, 2008 | 07:00 PM
finch13's Avatar
Don't worry, electrical is not my forte either. The black (-) wire coming from the connector, follow it. It should bolt down to the metal dash frame along with a ton of other ground wires (like 10 or so at each bolt).
Alternatively, put the red (+) prong on the positive wire going into the switch and then put the black (-) on a part of the dash frame or find a set of grounds.
Gerhard01
Oct 20, 2013 10:03 PM
Mario Locatelli
Oct 6, 2013 12:59 AM
New2JDM
Jun 22, 2012 06:30 PM
ouchevelles
May 16, 2007 01:05 AM
bear67
May 29, 2005 04:10 PM
