Elusive oil leak
Old Aug 7, 2011 | 01:22 PM
tashier's Avatar
A box wrench, I loosened the plastic wireharness near it so I could move it down just enough to get like a 1/10th of a turn out of it. Luckily, it was loose as soon as I cracked it so I was able to finger it out the rest of the way. I also had removed just about everything else around it. Distributor, vacuum and small coolant line, intake tube of course. I had to pull the distributor anyways but that's pretty easy.
Old Apr 11, 2012 | 08:48 AM
msffletch's Avatar
Im having the same problem with a 95 accord vtec. Have changed the sending unit, vtec solenoid, and valve cover and still pouring oil. Any help on this?
Old Apr 12, 2012 | 09:10 AM
tashier's Avatar
There is also the distributor o-ring in that area. It's pretty easy to change out and I did it as well. You did both vtech gaskets too? That's where my main oil leak source was. Those rubber gaskets just get baked and hardened.
Old May 12, 2012 | 10:33 PM
GoneHonda's Avatar
Default I am having the same exact issue not vtech
I think it my head gasket tho.. which sucks.. but I cant see oil coming from anywhere else...
Old May 15, 2012 | 12:57 PM
tashier's Avatar
How many miles? I suppose it's possible but unlikely since I've had over 300,000 miles on a headgasket before. Has it been overheated? Have you completely cleaned the engine before trying to locate the leak?
jeranso
Jun 6, 2013 01:18 PM
Incognitjo
Aug 24, 2012 06:11 PM
GoneHonda
May 25, 2012 11:45 PM
frost506
Jan 16, 2012 07:21 PM
mamtsberg
May 30, 2010 07:04 AM
