Engine oil change
Old Jul 3, 2014 | 10:19 PM
jayo2009's Avatar
Default Engine oil change
Ok so my accord sport is almost ready for its first engine oil change. It recommends every 4 months or 5000 miles but also has an oil life sensor which is still at 40% still. My 4 months is in a couple weeks and I'm only at 2800 miles. My question is should I wait til my service light comes on or go by the 4 months 5000 miles. I don't want them try saying I'm not changing it on time and try voiding my warranty if something goes wrong,
Old Jul 3, 2014 | 10:33 PM
shipo's Avatar
Where are you reading the four month or five-thousand mile oil change recommendation?
Old Jul 3, 2014 | 10:42 PM
The recommended oil change level is not specified at 4 months or 5,000 miles. The car has the maintenance minder. 40% on the maintenance minder means the calculated oil life left is between 40 to 31%.
Your car came with Honda's 0W-20, which is full synthetic.
In addition, the factory-fill engine oil has molybdenum (“moly” for short), a special lubricant applied by the factory to critical engine components during assembly. So, it is not recommended to change the factory fill oil until the recommended maintenance time. -- Just be sure to check the engine oil level and top off as necessary in the interim. You can wait to change the engine oil.
TexomaAccord
Dec 22, 2014 11:06 AM
PinkFloridaFlamingos
Aug 24, 2011 12:35 AM
chris h
Apr 3, 2011 10:01 AM
jeffersonkim
Nov 18, 2009 08:59 AM
ziwang55
Jun 6, 2008 01:25 PM
