Engine stops right after start
I have a 1991 Honda Accord LX. When I try to start it it will start but the second I releasethe key to the run position the car shuts off again. If I give it gas the car with reach higher RPM's but then still shut right back off. The power windows also stopped working, the lights on the dash no longer light up, and the fan for the A/C and heat doesn't work. I have no idea what could be wrong. It it almost seems like its some anti-theft thing but I think the car is too old to have one. I pull the battery off for 10 mins to reset the computer but it didn't help. Does anyone have any ideas?
One simple thing to try, but it might not actually prove anything...
Start the engine, but don't completely release the key. Let it spring back just enough so the starter quits running. If it stays running, then quits when you actually let go of the key, that would be a bad ignition switch. If you can't get it to keep running by holding the key then it really doesn't prove anything.
Baztaz
Mar 2, 2014 10:24 AM
