Engine swap wiring problems
Old Oct 6, 2011 | 08:46 PM
Shiloh's Avatar
Default Engine swap wiring problems
1995 Accord 2.2l lx at. Did a engine swap with a same year accord,used the wiring harness from the swap engine.Engine runs fine but now the windows will not roll down,All the panel gages do not work.The fans at the radiator do not work,and the safety switch for shifter will not ingage the seliniod to allow the shift out of park.Please help if you can
Old Oct 6, 2011 | 09:31 PM
Looking at the various electrical circuit diagrams, for the windows, gauges, radiator fan, etc., the common thing I find is possibly the grounds at G402 and G404.
Radiator fan control module ground via G402 and G404. Power window master switch and driver's window motor ground via G402 and G404. Various gauges ground via G402 and G404.
Of course, there are other grounds in the respective circuits too; but, those two grounds may be a good place to start due to the commonality.
Old Oct 7, 2011 | 08:46 AM
Shiloh's Avatar
Thanks Redbull-1 I check those grounds and the seem to be good,the attachment you send helped a lot,while I had the car running I jumped the wiring at the thermostat the fan came on so maybe the sensor is bad,thats one down,need help with the other problems
dr.deuss
Jan 5, 2014 03:25 PM
phantomgrey92
May 15, 2013 05:35 PM
SuperMidget
Aug 30, 2012 12:08 AM
alexdc
Jun 16, 2010 07:17 PM
KimberlyC
Apr 16, 2006 11:51 AM
