first gear problems
Old Dec 30, 2006 | 04:17 AM
94Jdmh22accord
Default first gear problems
I have a 94 accord with jdmh22 engine swap and about a month ago my first gear has been very hard to put in. It just gets stiff and have to push hard on it. other gears are fine jus the first feels like something is blockin it .wondering wat could be causing the problem.
Old Dec 30, 2006 | 04:15 PM
hondadude's Avatar
Default RE: first gear problems
What fluid is in the trans?
Old Dec 30, 2006 | 05:49 PM
deserthonda's Avatar
making sure you got the correct fluid as Dude suggest is a good idea.. also chk to make sure the linkages are not binding, bent and installed properly , if it was working ok before the swap , that's what i would check, ,,,,
and the fluid should be engine oil ( 5w-20, 10w-30 ) 3 qts ..do not use gear oil ( 80, 90 w)
Old Dec 31, 2006 | 05:13 AM
94Jdmh22accord
alright thx guys ill get the fluid changed and see wat happens from there
Old Dec 31, 2006 | 06:59 PM
keep us posted
letsclique
Jun 18, 2016 04:29 PM
d0n
Feb 4, 2013 08:45 AM
droidboy
Apr 3, 2012 02:43 AM
eckhart
Jun 29, 2011 06:33 AM
daddy
Apr 24, 2006 10:15 PM
