Flashing battery and oil lights
Old Oct 29, 2008 | 01:08 AM
deserthonda's Avatar
Default RE: Flashing battery and oil lights
have the alternator tested most likely you got a bad 1 ...
Also, i have seen a bad alternator make the oil lite flash as well
But to be on the safe side,you should chk the oil pressure ..
Old Oct 29, 2008 | 06:55 AM
MikeT's Avatar
I should be able to get it checked on Friday.
Old Oct 31, 2008 | 08:45 AM
MikeT's Avatar
I took the car to Advance Auto and they checked out the battery and alternator yesterday. The battery was fine and the alternator put out 13.82 volts and 66 amps. My headlights do not dim and the person testing said that would be a sign that the alternator was going so I guess it isn't...... We checked the battery cable connections and they were all very tight and had no corrosion on them. So, I still have the occasional flashing issue. I guess I can just ignore it. I am not sure what else to do.
BTW, when starting the car the battery light turns on solid when the key is first turned to the on position as it should. This leads me to believe that there is no physical connection problem right behind the dash light which was my other concern.
Old Feb 2, 2009 | 07:38 AM
MikeT's Avatar
You need a rectifier assy and brush assy. They are easy to replace. Purchase or download an Accord shop manual. Rebuild procedure is in manual. Don't replace bearings unless they are noisy.
Rebuild parts are available online from many sources.
Well, the flashing/flickering battery light is becoming more frequent so I guess I will need to take a look at this rectifier and brush assembly. I am not near my Haynes manual right now, is the procedure difficult? Are the parts expensive or is a rebuilt alt about the same cost?
Old Feb 2, 2009 | 07:56 AM
MikeT's Avatar
I looked at Majestic Honda and the rectifier is $153.00. At PartsTrain.com, I can get several completely rebuilt alternators for less than $161.00.
Has anyone had any luck with the rebuilt parts from PartsTrain?
Old Feb 2, 2009 | 01:59 PM
MikeT's Avatar
I did a little calling around to come to find out that it probably is (as Texas Honda said) the brushes. Is this a difficult procedure to replace??
Mr. 99
Feb 6, 2019 04:56 PM
sbarton1
Oct 29, 2014 08:46 AM
john germer
Sep 8, 2013 05:44 PM
rollo2000
Oct 19, 2012 06:04 AM
poynterandy
Jul 3, 2011 03:23 AM
