Fuel filter
Old Aug 8, 2008 | 04:26 PM
jerrym's Avatar
Almost A Senior Member
Default Fuel filter
Forgot to ask about this.
Does anyone know how often, or if at all you need to replace the fuel filter on my 97 Accord, 2.2 liter.........not sure when it was done last but might change it out. A little tough to get to also.
Thanks!
Old Aug 9, 2008 | 08:06 AM
Default RE: Fuel filter
Fuel filter is not a maintenance item, and is replaced only when fuel pressure indicates a problem. The fuel pump has an inlet screen that will catch any typical rust so fuel filter only catches very tiny particles, and should last very long time.
My 94EX has 225K miles on original fuel filter w/o problems, though I've had to replace fuell pump. The tank was pristine w/o rust so if this is typical, blocked filters are unlikely.
BTW, the fuel filter is very difficult to access in these cars, but do-able w/ special tool (crows foot open end socket).
Old Aug 9, 2008 | 09:20 AM
jerrym's Avatar
TexasHonda,
It does look tough to get to. Maybe the best thing is to check the fuel pressure first. Have you ever ran a fuel psi check on your car?
JM
Old Aug 9, 2008 | 12:55 PM
I’ve never performed a pressure check on mine other than cracking the bleeder port to check for a spray of fuel. A fuel pressure check kit should have this fitting or you’ll have problems finding a fitting. I have searched for the fitting and not found readily available.
Why do you want to check fuel pressure? Starting or performance problem?
Good Luck
rockhoundrob
Apr 11, 2014 11:41 AM
Special_K
Aug 12, 2011 04:16 PM
bjr001
Mar 5, 2010 07:31 PM
mojorison_75
Dec 4, 2005 06:40 PM
Buckeye
May 8, 2005 12:41 AM
