Fuel injectors
Old Jul 3, 2020 | 02:10 PM
Jules69's Avatar
Default Fuel injectors
can honda accord 5th generation fuel injector be used on a 6th generation
Old Jul 3, 2020 | 02:25 PM
The easy check is to look up the OEM part number for the fuel injectors for your 6th gen accord, then look up the OEM part number from the 5th generation donor. Use a site like hondapartsnow.com
If they have the same part number, then you can use them If they have different OEM part numbers, then something is different between the parts (the difference could be anything like size, electrical connector, current needed to open, etc. and may take some modifications to work.
Old Jul 3, 2020 | 02:44 PM
Jules69's Avatar
They are different OEM#. Do you know where I can find out exactly what the differences are?
The Toecutter's Avatar
I don't think so. The 5th gen injectors have a resistor block wired in, while the 6th gen doesn't use the resistor block at all.
The 5th gen Accord is 94 thru 97, while 6th gen is 98 thru 2002.
Old Jul 3, 2020 | 02:48 PM
Jules69's Avatar
That is just what I needed to know. Thanks a ton for your help. I will definitely be back here for future advise/guidance.
sgull
Jul 1, 2013 09:37 PM
MMoreira
Apr 11, 2011 11:56 AM
honDUHchick
Mar 5, 2011 07:40 PM
fortyfootelf
Jan 22, 2010 07:15 PM
freakrz
Aug 29, 2007 02:08 PM
