fuel,intake,or clutch problem?
Old Mar 3, 2010 | 01:29 PM
corlude's Avatar
Default fuel,intake,or clutch problem?
driving along doodahh doodahh go to step on the gas to get around this truck an bam nothing...no power from the motor just kinda bogs out an doesn't want to go.buuut the weird thing is if i match the gas pedal to my rpm's an slowly press the gas down as im going faster and faster it runs fine...i dont get it.any answers?
Old Mar 3, 2010 | 02:21 PM
deserthonda's Avatar
if clutch were slipping the rpm would go high,,,,,,,,
any codes ?? chk fuel pressure, ..
Old Mar 3, 2010 | 03:41 PM
corlude's Avatar
no CEL but then again i had my ecu chiped so i dont know it might be throwing a code but the chip is interfering
Old Mar 4, 2010 | 03:51 PM
corlude's Avatar
anyone?
Old Mar 4, 2010 | 05:01 PM
A chipped ECU shouldn't prevent the ECU from throwing codes, but I am not sure about that. You may want to contact the manufacturer of the chip to verify.
Does the check engine light turn on for about two seconds when you first turn the key to the II position?
Are the maintenance items up to date, like spark plugs, dist. cap, and dist. rotor?
Old Mar 6, 2010 | 12:32 AM
corlude's Avatar
i pulled the cap an it looks good.and yes the CEL comes on for a couple seconds and then turns off.brand new ngk's so plugs are good...it feels like a fuel system problem but im trying to pin point it before i replace injectors/fuel pump.iv already replaced the fuel filter an it was full of all sorts of goodies for all i know the entire full system is full of junk.this car sat for a few years before i bought it off my brother.
Old Mar 6, 2010 | 12:34 AM
corlude's Avatar
yes i need to check the fuel pressure also
Old Mar 6, 2010 | 12:37 AM
corlude's Avatar
also it doesn't do it when im parked. only while im moving and only after it warms up.
vetski179
Feb 24, 2015 04:26 PM
jkrueger2020
Mar 10, 2011 02:18 AM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
