Fuel problem on 1989 accord
Old Jun 30, 2009 | 01:28 PM
Rcruz's Avatar
Default Fuel problem on 1989 accord
I am having a problem with power to the fuel pump. I notice this happening more after I have driven around and let het car sit for about 20 mins. Last time this happened is when I moved the car out of the garage. It decided not to start. The reason I say power to the fuel pump it because when I turn the key on I can hear the fuel pump. When it decides not to start. I get no sound. After letting the car sit for awhile them it would want to start.
Do you think a bad relay would cause this?
I have replaced the fuel pump, filter and 2 injectors.
Any help would be greatly appreciated.
Old Jun 30, 2009 | 02:35 PM
Does it happen more often when the car's interior is HOT? If so, then it's pretty classic for a bad main relay.
If you're good with a soldering iron, pop the relay apart & re-melt the solder joints on the circuit board.
Old Jul 1, 2009 | 09:36 AM
Rcruz's Avatar
Well it happens more when the car is warmed up and yes the last time I had the car outside when this problem occured. I will pull the main relay and give that a try.
Thanks
stubby1962
Mar 30, 2025 07:17 PM
Jklung
Mar 20, 2013 03:01 PM
cherbi7
Feb 1, 2011 09:34 AM
ohanahorse
Dec 21, 2009 12:59 PM
Tz Harley
Aug 16, 2009 07:08 PM
