Fumes
Old Sep 3, 2011 | 12:15 AM
A Carter's Avatar
Default Fumes
Hello all! My first post so here it goes. I just purchased a 95 accord V6 and overall it was a good buy. One of my issues is strong exaust fumes from time to time and I need to know where to look to get rid of them.
Two codes came up when I purchased the car so I got it alittle cheaper than the previous owner wanted. One of the codes is an O2 sensor and the other was a purge valve malfunction. I also just discovered today that the previous owner removed the catylic converter so I'm wondering if that could be the problem. I'm a decient mechanic but need to get familar with the HONDA's. My first Honda but definitely not my last!!! Help me out guys!
Old Sep 3, 2011 | 02:36 AM
Put a new converter back on before you get stopped in an e-check and get a pretty hefty fine for not having one on your car..
Old Sep 3, 2011 | 05:42 AM
piggylover1985's Avatar
It will set an O2 code for not having a cat (unless you trick the sensor) and it will also run richer that's why you smell the fumes.
Old Sep 3, 2011 | 10:10 AM
A Carter's Avatar
Thanks guys! I'll put the cat back on ASAP!
Old Sep 3, 2011 | 10:20 AM
Tek310's Avatar
the cat is surely giving you the smell. the evap purge valve will give you a fuel/exhaust smell as well
however the rear o2 sensor does not control fuel/air ratios. it is only there to tell if the cat is doing its job. so it will not give you a rich mixture
jon.hand
Jun 15, 2011 08:34 AM
valbball
Aug 27, 2010 10:01 PM
valbball
Aug 25, 2010 06:11 PM
larrystout
Aug 2, 2010 10:11 PM
Mikkos21
Oct 20, 2009 04:04 PM
