Gas cap light
Old Mar 8, 2021 | 01:23 AM
jdeleon's Avatar
Default Gas cap light
How do I get my check gas cap light to turn off on my 2010 Honda Accord 2.4 liter? I already replaced the gas cap.
Old Mar 8, 2021 | 04:14 AM
Seanjordan20's Avatar
You can hold the negative and positive cable together for a few minutes. Just make sure they are disconnected from the battery first.
Old Mar 8, 2021 | 07:37 AM
shipo's Avatar
Take a look at replacing the Purge Control Valve.
Old Mar 8, 2021 | 09:54 AM
It is a relatively common issue with 8th generation Accords. The indicator will usually go away in a day or two of driving.
Honda has technical publications regarding turning the gas cap at least 3 "clicks" after every fill-up.
If the problem persist even with turning the gas cap at least 3 clicks, it may due to something other than the gas cap.
Old Mar 8, 2021 | 10:03 AM
I just went through this two weeks ago on my 07 and was wondering why it didn't reset. When I held the positive and negative cables together it cleared it. I only changed the gasket on the cap. You can also clear the warning with a more than mediocre OBD2 reader. Good to know it will clear after a couple days on its own.
Jared-95hondaaccord
Sep 12, 2011 02:06 PM
Accord Owner
May 12, 2010 12:12 AM
status
Feb 3, 2008 11:32 AM
dmiscae
Apr 14, 2007 03:53 PM
thunder_x
Jun 13, 2006 08:12 AM
