gear shift light out
Old Dec 1, 2006 | 12:10 AM
MichaelEXL's Avatar
Default gear shift light out
My gear shift light on the shifter is out, how easy is this to fix without going to the dealer. I have a 1996 Accord EX-L that just turned 190,000 miles today.
MichaelEXL's Avatar
Default RE: gear shift light out
Yes its the one on the console not on the dash
Old Dec 1, 2006 | 01:20 AM
deserthonda's Avatar
you need to remove the center console and chk to make sure wiring and connections are ok,,,,,,,,if ok chk to see if you are getting power and ground at the little socket if you are replace the bulb ,,,,,\ or just stick a bulb in and see if it works ( make it faster ) if it still does not work than diagnose ,, I would never tell someone to install a part before diagnosing properly but bulbs are real cheap
Old Dec 1, 2006 | 10:50 PM
smaglik's Avatar
I know it's your baby, but your car is 10 yrs old. My 88 does that. I just deal with it.
Old Dec 2, 2006 | 12:01 AM
MichaelEXL's Avatar
Default Gear Shift light
Well I fixed it today, it was a tiny bulb that you can get at Nava for $1.69, but to put the bulb in is not easy. I was able to take the arm rest, center console out, the bulb holder is underneath the PRNDL, un the upper left hand corner. I had to to get the dealer to re-install the console and all. Make sure you don't lose the tiny screws at all.
The normal charge for the dealer is $45.00 to install the bulb.
It's so much easier to see at night espically since it gets dark so early here.
Old Dec 3, 2006 | 12:10 PM
Default RE: Gear Shift light
glad that it is done ...
Old Nov 27, 2009 | 02:48 PM
accordguru
Here is a nice tutorial with picture. No need to remove entire console: http automotive dot trevorated dot com
Last edited by JimBlake; Nov 30, 2009 at 07:13 AM. Reason: no active links, please
letsclique
Jun 18, 2016 04:29 PM
d0n
Feb 4, 2013 08:45 AM
ErikS88
Dec 20, 2011 06:20 PM
themacmagician
Jan 14, 2008 12:49 PM
hondadad69
Jul 26, 2007 05:17 PM
