getting into gear on automatic
Old Sep 21, 2017 | 02:37 AM
parpat's Avatar
Cool Vacuum on gear shift lever ??
As I mentioned before, was (and still are0 having trouble getting out of park..
BUT it seems that if I 'gun' the engine twice it shifts just fine..
vacuum leak maybe in brake system of actuator /
Old Sep 21, 2017 | 07:52 AM
Dr. Drivability's Avatar
Go to Honda, spend 8 buck on a brake lamp switch and be done with it.
Old Sep 21, 2017 | 05:17 PM
parpat's Avatar
Unhappy gear shifty
HUH, how does 'gunning the engine equate to brake switch ?
got a battery recall, so will take it in, and have em fix the problem too !
Old Sep 21, 2017 | 06:11 PM
The shift lock is all electrical. It doesn't make sense that revving the engine fixes the problem unless you have a low voltage problem at idle.
Old Sep 23, 2017 | 11:11 AM
Wondering if there is something up with the TPS readings?......yea, the '16 might be different but on some of the older ones, if the PCM "thinks" the gas pedal is down then it won't let you shift out of park. Just a thought
Starchyldd
Jun 6, 2017 07:06 PM
letsclique
Jun 18, 2016 04:29 PM
PinkFloridaFlamingos
Jul 28, 2012 04:55 PM
turborabbit
Dec 10, 2009 12:26 PM
98accordlx
Feb 11, 2008 11:32 PM
