Got a o2 sensor question....Help!
Old Jul 28, 2008 | 10:36 AM
Ranmaster
Default Got a o2 sensor question....Help!
I've got a 2004 6MT coupe. One of the o2 sensors needs replacing. The scanner say's "Bank 2 Sensor 1". The parts Lady said it was the main sensor in the front by the header. Her reason for saying that was only because it said "sensor 1". They had no idea what "bank 2" meant. Could anybody enlighten me on what "Bank 2" means or the location of "Bank 2 Sensor 1"???
Thanks!!!!
Old Jul 28, 2008 | 10:48 AM
Tippman7641's Avatar
Default RE: Got a o2 sensor question....Help!
i believe bank in this instance is likt a set, like a set of chrismas lights, only instead its sensors
Old Jul 28, 2008 | 12:10 PM
6MT only comes on V-6, right? You dont say V-6 so you make us figure this out...
Look at the catalyst on the front of the engine. Sensor 1 is at thetop & sensor 2 at bottom.
Bank 1 & 2 refers to the same configuration on the OTHER catalyst on the back side of the engine. I dont have a V6 so I dont know which bank is which.
If we knew the actual error code number we might be able to help more.
Old Jul 28, 2008 | 12:23 PM
Ranmaster
It's a 6 cylinder. I just need to know if Bank 2 is the side by the firewall or the side bythe rad...
Old Jul 28, 2008 | 01:37 PM
Thats the part I dont know. I dont have a V-6 so I never bought the V-6 supplement for the Helm repair manual.
Process of elimination...
P0130, P0131, P0132, P0133 are for the PRIMARY sensor on a4-cyl engine, which I THINK uses the Bank 1 codes.
pondrun
Nov 8, 2021 09:40 AM
choi
Apr 18, 2014 08:43 PM
mixedboydriver
May 20, 2011 05:14 PM
one35studios
May 16, 2008 10:20 AM
