grinding going into reverse
Old Mar 6, 2007 | 11:51 AM
rwerber
Default grinding going into reverse
I have a 93 Accord that makes a loud grinding noise going from park to reverse. This noise can still be heard (at a much lower level) in neutral. The noise goes away if I shift into D4 and then to neutral. My car is an automatic and there is no problems with the forward gears.
The noise only happens when I try to shift into reverse.
Thanks in advance.
rwerber
Old Mar 9, 2007 | 11:33 PM
hondadude's Avatar
Default RE: grinding going into reverse
Not much you can do to fix that problem; change out the fluid use Honda Z-1 ATF.
You are having low pressure internally of the transmission.
RegisWhite
Nov 16, 2018 10:46 AM
Joseph97297
Jun 28, 2013 08:12 AM
HYDRALOX
Dec 31, 2012 08:46 AM
shrekdiesel44
Jul 8, 2007 09:01 AM
ziptie
Jan 31, 2007 12:16 AM
