Grinding noise
Old Aug 23, 2012 | 11:52 AM
Str2010's Avatar
Default Grinding noise
can someone try to help solve this for me. its a 2001 honda accord LX.
there is this grinding like sound coming from the rear passenger side of the car. first i thought it could be the muffler like most of you might be thinking so far but i got it lifted to change my muffler and asked them to check if the rubber or anything is gone. they checked and it wasnt the muffler 100%. i know little to nothing about mechanics so bare with me.
this noise only comes after i drive the car for a good while like 30+ minutes. it only comes when i am stopped, when in park or when in drive or reverse but im holding the brakes if im in drive or reverse and let go of brake it stops. also when im on a downhill it makes the grinding noise loud.
the only mech i know in the rear is e brake since its FWD. could it have anything to do with the e brake? if not can someone give me any ideas. also i am going to a garage to fix a non related issue in a few weeks when i have money and ill ask him about it. i just wanna know if it a serious problem or not.
sorry for the long boring question. but thanks in advance to anyone who can help me!!!
edit: it mainly only happens on a downhill area if its not downhill i have to turn the steering wheel to a certain position and it starts grinding.
Old Aug 23, 2012 | 08:12 PM
Sorry, I'm easy to confuse.
To me this is sounding like a wheel bearing issue. But at the same time I can't tell if this is a rear brake issue......
Old Aug 24, 2012 | 10:59 AM
Str2010's Avatar
okay thanks ill find out in a week or two when i take it to a shop and tell you if its that or something else hopefully nothing serious.
Old Aug 24, 2012 | 11:34 AM
Silver6gen's Avatar
have them check your brake pads (you can even do this by looking at them through the rim if you have alloys) Worn out brake pads create a metal on metal scraping sound when they are ready to be replaced. Its designed to do this.
If the wheel bearing is going out and you think its the right rear then when you are driving and go around a right hand corner (40-50mph) the noise should lessen and subsequently going around a left hand corner will make it more pronounced.. If it is the left rear then going around a left hand corner will lessen the sound.
Old Aug 24, 2012 | 11:51 AM
moey's Avatar
sounds like a brake problem my guess, my experience with wheel bearings is the noise went away when I put my foot on the brakes. Ive had some weird sounds come from my brake drums from scale/rust buildup on the inside of the drums but I suspect your car had rotors.
Old Aug 25, 2012 | 10:31 AM
Str2010's Avatar
no this noise ONLY happens when the car is fully stopped and only after the engine is really warmed up. and if im parked on a downhill its really loud.
stockxplorer
Sep 25, 2022 04:15 PM
SilverBullet
May 16, 2015 10:59 PM
encan
Mar 8, 2007 03:51 AM
guitargod33
Sep 10, 2006 09:13 PM
