Having a issue with my 2009 Honda Accord Remote start
Old Nov 15, 2014 | 06:46 PM
Stephen Smiokie Madd's Avatar
Default Having a issue with my 2009 Honda Accord Remote start
Having a issue with my 2009 Honda Accord remote start. Just recently it will not activate no more then 10 feet away, plus at times the transmitter does not show the car has started when it does start up remotely. I have changed the two batteries, and tested them to be fresh a little over 3 volts each. Any help would be appreciated. Thank you in advance.
Old Nov 15, 2014 | 07:05 PM
Dakotademon7's Avatar
The remote may just be warn out. They do take a bit of abuse. You can also take close look at the battery holder mounts and contacts. Make sure the contacts are clean and holding the battery snug. Check the mount points to make sure there not separating. Common problem do to dropping .
Old Nov 15, 2014 | 07:47 PM
Thank you Dakotademon7, The contacts are clean, and I pulled them up some for better contact. The strange thing is that I checked the stats of the remote, and the battery level reads only half charged but I know the bats are fully charged because I checked them with a meter. I will test again tomorrow.
I know this remote starter was covered for 36 months or 3 years, but do you know if having a Honda Care extended warranty that this remote would be covered under it, reed the contract which does not state either way?
philmaine
Sep 15, 2014 01:48 PM
Young_&_Fly_
Sep 7, 2011 10:56 PM
rsmith28us
Jan 30, 2011 02:17 PM
Julieanne1976
Aug 21, 2009 09:20 PM
05HondaAccord
May 5, 2008 11:24 PM
