Head gasket? 1995 Accord
Old Oct 25, 2008 | 06:32 PM
kris_loehr's Avatar
Default Head gasket? 1995 Accord
My car overheated and I just found and fixed the coolant leak which was the heater hose at the block but something is not right. If I crank the engine with the radiator cap off coolant will spray everywhere. It doesn’t smoke or have any sighs of water in the oil but will overheat if left to idle for a long time over an hour. It also loses antifreeze. It has been sitting for a year and I wonder if the head gasket is blown. I have to clean off the spark plugs to get it started then after it warms up starts fine.
Old Oct 26, 2008 | 01:05 PM
kris_loehr's Avatar
Default RE: Head gasket? 1995 Accord
Do you think this is the head gasket?
Old Oct 26, 2008 | 03:42 PM
boostedtsi's Avatar
If you coolant is getting over pressurized when running it can be a few different things. A blown head gasket is just one.
Remove the plugs, if 2 are dirty and the others spotless then yeah, your HG is toast.
Going back to the coolant pressure. If the engine is cold and it is gushing out like that that is a clear sign of a failed HG. The compression pressure has found a weak point and pushed its way into the coolant passages. Also check your motor oil dip stick, if it is any sort of brown, especially tan it is definitely toast and do not drive it or you risk bearing damage.
Old Nov 12, 2008 | 06:25 PM
kris_loehr's Avatar
I can't find the post for changing the timing belt. Help.
Old Nov 12, 2008 | 06:36 PM
lopez1414
Apr 27, 2014 10:50 PM
kris_loehr
Nov 9, 2008 03:47 PM
thunder_x
Jul 9, 2007 11:57 AM
mdd0127
May 21, 2007 09:27 PM
dodins
Mar 18, 2007 08:10 PM
