Headlights shut off.
Old Oct 1, 2010 | 07:28 PM
FdgeKake's Avatar
Default Headlights shut off.
I have a 1986 Accord LXi 3 door with 216,000 miles on it. When ever I drive at night my headlights will sometimes go out and then back on. This only happens when they are on low beams and not high beams. When it first happened it only went out for a second or so, but now it can go out for more than 5 seconds. I can switch them to high beams and all is fine. But when I turn them back to low beams the lights will sometimes shut back off. I have noticed when this happens my brake lights and are still on. Just the headlights shut off. Any clues on what it could be?
Old Oct 2, 2010 | 08:35 AM
I don't have an 86 shop manual, but looking at a 90 Accord manual, there is a dimmer relay that is toggled by the column stem switch. The dimmer relay contacts may be worn or damaged. On the 90, the dimmer relay is in under hood fuse box.
Old Oct 2, 2010 | 02:01 PM
FdgeKake's Avatar
Sweet. I will check out where that is and get started. Thanks for your help.
tomd
Mar 9, 2013 06:35 PM
switch
Dec 2, 2012 10:13 AM
live2rice
Apr 18, 2007 09:27 PM
jshrade
Dec 11, 2006 01:38 AM
pixelmonkey
Sep 3, 2006 04:18 AM
