hearing noises. need help
i have a 1996 honda accord that i use for a work car. it has 190,000 miles on it. everytime i turn the wheel, i hear a screaching noise. any suggestions?
Get a helper & open the hood. When turning the wheel (to make the noise) listen up front to pinpoint the location.
Power steering belt is the more common source of the noise. You can check that by squirting a little water on the belt & see if it gets quiet. Fix is probably get a new belt.
If the sound comes from down at the wheel, then it's probably a balljoint seizing. Get that replaced before the wheel falls off. Fortunately this one is less common.
Bexar
Jun 19, 2011 06:10 PM
SunImNw
Oct 16, 2008 08:14 AM
