hearing noises. need help
Old Feb 5, 2013 | 05:39 PM
brabs's Avatar
Default squeaky steering wheel
i have a 1996 honda accord that i use for a work car. it has 190,000 miles on it. everytime i turn the wheel, i hear a screaching noise. any suggestions?
Old Feb 5, 2013 | 05:43 PM
I moved your help thread. Please read the forum rules and watch where you post, do not post help questions in the DIY section.
Old Feb 5, 2013 | 09:00 PM
Get a helper & open the hood. When turning the wheel (to make the noise) listen up front to pinpoint the location.
Power steering belt is the more common source of the noise. You can check that by squirting a little water on the belt & see if it gets quiet. Fix is probably get a new belt.
If the sound comes from down at the wheel, then it's probably a balljoint seizing. Get that replaced before the wheel falls off. Fortunately this one is less common.
pancho88
Mar 20, 2012 06:06 PM
SunImNw
Oct 16, 2008 08:14 AM
maro
Jan 7, 2008 01:06 PM
