Heat Q
New here can really use some help Just bought my 05 accord never checked the heat, Tuened to heat ,nothing. noticed the cable to the heat valve under the hood didnt move. I was able to manually open valve. any iideas? Thanks
You can purchase a good shop manual for your vehicle from ebay seller, automanualsource for $21.99. This will have the detailed guidance to locate, troubleshoot, and repair/replace the heater valve actuator motor.
When you turn the temperature ****, it commands air-mixing doors as well as the water valve. Not sure, but probably one motor drives the air-doors as well as a lever that push/pulls the cable going out to the valve.
#12 at the top is the cable for the water valve. But this picture doesn't reall show where it's connected inside...
skijour
Aug 15, 2012 08:31 PM
