heater/ ac control panel will not turn off 94 accord
Old Dec 9, 2012 | 08:40 PM
oscarf22's Avatar
Default heater/ ac control panel will not turn off 94 accord
its weird I'm almost positive I need a control panel. it started yesterday the orange an green light for air circulation when I turned the car off the light stayed on? i tapped it really quick an it turned off.today it done it again but now when I turn the key off the drivers side fan comes on? now it will not turn off. isn't there a fuse I can pull until I
make it to the junkyard? I think the fuse is under the Hood. cause im sure the control panel n fan are going to kill my battery
Old Dec 10, 2012 | 01:36 AM
oscarf22's Avatar
the fan stopped running on its own but still orange light stays on on control panel u can turn the heat on well 1 2 3 an 4 power levels work without the key in I'm thinking its a relay or fuse
Old Dec 10, 2012 | 07:02 PM
Relay is suspect......in the under dash relay/fuse box is where you will find it. When this happens again, pull the relay and see if it stops....then test the relay as there is a slight poss that something else is causing the issue.
Old Dec 10, 2012 | 07:04 PM
Ohh...wait. Is the cooling/cond fan for the rad running or the blower motor?
Old Dec 14, 2012 | 12:02 AM
oscarf22's Avatar
it was definitely the relay I had the flu so I didn't mess wit it until today. the fan still stays on for about 4 mins but it turns off has to b just cooling the motor thanks for the help y'all I sure appreciate it
Treaddirt
Dec 25, 2018 12:29 PM
tomd
Mar 9, 2013 06:35 PM
Wrecked94Accord
Jul 17, 2011 07:39 PM
blan
Mar 31, 2008 11:45 PM
