heater blower relay
Did you check the fuses in the engine fuse box?
The blower motor relay or the heater fan switch are the next electrical component to check. The relay is in the dash fuse box for a 95, but I am not sure where it is at for an 03 accord. If there is a relay that is the identical, then swap them and see if the blower works. If it does, then the problem is solved - get a new relay. You can jump the proper terminals, but I do not know which ones to jump.
Honda Man For Life
Apr 9, 2012 09:38 AM
