Heavy / Stiff Clutch Pedal.....SOS
Old Aug 26, 2010 | 04:31 AM
spartan615's Avatar
Default Heavy / Stiff Clutch Pedal.....SOS
It's an 04 accord with 115K. The clutch pedal is very hard to push down as of recently. I started at the slave and replaced that. Still no change. I was thinking of changing the master next (which seems to be buried back there). Could it be the clutch itself? Thanks for the help.
Old Aug 26, 2010 | 06:33 AM
Get a friend to help...
V-6 or 4-cyl engine??
Take the clutch throw-out lever & push it against the slave, compressing the piston inwards. While holding it, have your friend try the clutch pedal & pay attention to the force needed. Don't pinch your fingers...
At first the motion will only take up the slack that you created by compressing the slave piston. Does THAT require excessive force or is it easy? If EASY, then the problem is in the clutch.
If that first part of the pedal motion requires excessive force, then look at the clutch pedal hinges, or the clutch master cylinder.
Robert Harp
Jan 8, 2024 06:10 PM
ewill23nm
Apr 19, 2014 03:21 AM
Cody_754
Sep 10, 2012 07:15 AM
tamb
Jul 21, 2006 01:05 AM
vov4ik1304
Jan 20, 2006 04:04 PM
