Help! 2003 Brake lights are out
Old Sep 28, 2011 | 10:53 PM
Ms.Apes's Avatar
Default Help! 2003 Brake lights are out
Both sides. Changed the bulbs and it doesn't work. Checked the fuse and it works as well (so does the horn, because it's the same fuse). What could be the problem??
(Oh, and I hope I posted in the right spot!)
Old Sep 29, 2011 | 11:29 AM
I would inspect the brake switch that is switched on/off above the brake pedal.
Old Sep 30, 2011 | 10:46 AM
onmyownaccord's Avatar
Ms.Apes,
Yup, I'm going to concur with PA on this one and suggest that perhaps the Stop Switch Assembly is faulty on your Accord. This part is located above your brake pedal. I don't know whether you own a coupe or sedan model but the OEM part number for the '03 sedan is 35350-S5A-J04.
For your reference, it is depicted as ref #7 in the diagram below:
Last edited by redbull-1; Jul 20, 2012 at 12:05 PM. Reason: removed live selling links
Old Sep 30, 2011 | 02:36 PM
AAPOQ's Avatar
Are you having trouble with your cruise control?
rudeg
Dec 31, 2015 07:23 PM
ryanvoey
Nov 22, 2013 05:16 PM
bougie_44
May 16, 2012 02:14 PM
dcmazz
Feb 16, 2010 08:34 AM
RR_Rex
Oct 19, 2007 01:03 PM
