Sponsored by:
Sponsored by:
Help! 2003 Brake lights are out
Old 09-28-2011, 10:53 PM
Ms.Apes's Avatar
Default Help! 2003 Brake lights are out
Both sides. Changed the bulbs and it doesn't work. Checked the fuse and it works as well (so does the horn, because it's the same fuse). What could be the problem??
(Oh, and I hope I posted in the right spot!)
Old 09-29-2011, 11:29 AM
I would inspect the brake switch that is switched on/off above the brake pedal.
Old 09-30-2011, 10:46 AM
onmyownaccord's Avatar
Ms.Apes,
Yup, I'm going to concur with PA on this one and suggest that perhaps the Stop Switch Assembly is faulty on your Accord. This part is located above your brake pedal. I don't know whether you own a coupe or sedan model but the OEM part number for the '03 sedan is 35350-S5A-J04.
For your reference, it is depicted as ref #7 in the diagram below:
Last edited by redbull-1; 07-20-2012 at 12:05 PM. Reason: removed live selling links
Old 09-30-2011, 02:36 PM
Are you having trouble with your cruise control?
rudeg
12-31-2015 07:23 PM
ryanvoey
11-22-2013 05:16 PM
bougie_44
05-16-2012 02:14 PM
dcmazz
02-16-2010 08:34 AM
RR_Rex
10-19-2007 01:03 PM
Quick Reply: Help! 2003 Brake lights are out
