help with 2004 honda accord not starting NEED HELP
Old Nov 27, 2011 | 05:36 PM
walkgiam2's Avatar
Default help with 2004 honda accord not starting NEED HELP
Hi I need help figuring out what my cars problem is. I've never had a problem before today it started fine before I went to work but then when I left work 8 hours later it flat will not start I had the battery tested I tried jumping it and still nothing all the lights and everything work fine the only thing it does when I turn the key forward is hear a single click sound from the starter. Please help
Old Nov 27, 2011 | 06:12 PM
walkgiam2's Avatar
no one?
Old Nov 27, 2011 | 06:51 PM
You pulled the battery and took it to a store and it tested fine.....correct?
What is the voltage of the "small" wire to the starter? I'm going to guess, testing needed on your part, that the starter is bad...IF you have 12v to the big and small wire of the starter and it does not start, have the starter tested, replace if needed....
Old Nov 27, 2011 | 07:21 PM
walkgiam2's Avatar
yea that's all i was able to do today I couldn't check the voltage
Old Nov 27, 2011 | 07:23 PM
walkgiam2's Avatar
couldn't check the voltage going to the starter that is.
Old Nov 27, 2011 | 07:30 PM
ok, when you can check the voltage to the starter...we will assume the amp's are good since you had the battery tested and it was good....
Old Nov 28, 2011 | 01:37 AM
Is the single click coming from the starter?
Old Nov 28, 2011 | 09:29 AM
jesandrw's Avatar
i am having the same problem with my 96, if you figure it out before i do let me know lol, and ill do the same!
Old Nov 28, 2011 | 05:49 PM
Are you getting voltage to the small wire at the starter?
Tashwinder Cheema
Jun 11, 2013 09:10 AM
Maverick7
Aug 31, 2012 10:21 AM
LaGirl
Apr 24, 2012 05:29 PM
tvsd
Apr 5, 2012 08:15 PM
cato2008
Aug 24, 2008 05:41 PM
