Help with 98 accord idling at 2000
Old Jul 29, 2011 | 08:35 PM
jfidelh's Avatar
Default Help with 98 accord idling at 2000
My accord is idling at 2k rpm. When i turn it on it goes from 1700 to 2 after a few minutes. I recently changed the TPS because the light came on for it.
I also just put a new starter in yesterday because it wouldnt turn on, just do a click''' noise. That solved that problem.
Yesterday had been the first day after a few weeks of actually driving the car around and I noticed that after the car being on for a minute the idle goes up and down, about to die and then back to 1700.
As of right now the only "check engine light" I have on right now is code either #1. I can not tell if it is a long flash or quick flash. If it is code #1 (Primary heated O2 sensor) I checked the clips to see if they are unplugged and they werent.
There are a few vac hoses that were unplugged so i just decided to 'T' them with others such as ones goes to the fuel filter i believe and one going to a part that the Cruise control cable connects to.
Would air escaping from BETWEEN the exhaust manifold to the downpipe be a cause?
Long story short, I need help lowering my IDLE. Sorry if I posted unrelated things, im just trying to figure this thing out.
Old Jul 30, 2011 | 01:10 AM
Since there were vacuum hoses undone, I would check the routing and vacuum hoses first. It would be worthwhile to get a 98 US accord shop manual. I got one from automanualsource on Ebay for $21.99 and it is well worth the investment.
Old Jul 30, 2011 | 06:39 PM
Probably have a diagram of the vacuum-hoses on the underside of the hood. (US-EPA requirement) Don't just tee them, it might not be the correct place.
Vacuum leak is a strong suspect for a high idle like that. Then look in the DIY section for a post I made about setting the BASE idle.
Old Aug 1, 2011 | 05:47 PM
jfidelh's Avatar
I don't have a stock hood so I cant check the vacuum diagram.
Since I posted this, everytime zI turn the car on from a cold start the idle fluctuates and i take offf and after 30 seconds of it doing so it will go away. My o2 sensor reads low/high input and i smell oil burning at times.
Old Aug 1, 2011 | 09:21 PM
FITV, checked and cleaned?
Old Aug 2, 2011 | 03:58 AM
engtaz's Avatar
Almost A Senior Member
I had some uneven idling so I used Seafoamed the car and idling problem was cured on my 99 accord 4dr 2.3 cyl.
Old Nov 6, 2011 | 10:20 PM
jfidelh's Avatar
I ended up cleaning the throttle body intake manifold with throttle body cleaner and it fixed the high idle problem. Remember to reset your ecu after doing this.
stubs
Jan 18, 2012 01:42 AM
kc0jsj
Feb 22, 2010 08:42 PM
bristang5
Aug 30, 2007 08:39 AM
d_10
Jul 31, 2007 10:35 AM
d_10
Jul 30, 2007 06:57 PM
