help- accord 2000 4cyl. tranny drain
Old May 10, 2018 | 07:57 AM
Eran Teitelbaum's Avatar
Default help- accord 2000 4cyl. tranny drain
hi
i wanted to drain the atf but rounded and destroyed the rectangular hole in the drain bolt.
what's next?
anyone had luck to open it with a pipe wrench or something?
thx
Old May 10, 2018 | 09:13 AM
Probably time to get professional help.
Or if you have a welder, weld a large nut to the bolt. IMO, a large ez-out will only round the hole further due to shallow depth of hole.
Maybe enough edge on the flange of the bolt to grip w/ vise grip?
Old May 10, 2018 | 10:18 AM
shipo's Avatar
Originally Posted by Eran Teitelbaum
hi
what's next?
thx
I haven't pulled a drain plug in any oil pan or transmission since 1999; instead I use an oil extractor:
Old May 10, 2018 | 03:58 PM
can't it damage the tranny?
Old May 11, 2018 | 11:52 AM
Won't hurt the trans but replace all ATF. ATF will be damaged from weldlng heat.
Old May 13, 2018 | 07:08 AM
Seanjordan20's Avatar
when I do something like that I spray it with pb blaster and let it soak for an hour. After I bang the next size in and get it off. Hasn't failed me yet. If you try it make sure you have a replacement. If it's like all other accords I can't see how the whole bolt is stripped to the end
Old May 15, 2018 | 11:14 AM
Eran Teitelbaum
Mar 29, 2018 09:11 PM
DemonYusuke
Sep 27, 2010 11:36 PM
teto
Apr 7, 2009 10:11 AM
jackkpts
Jul 8, 2008 10:14 AM
jon02accord
Mar 26, 2008 10:54 AM
